Auto Lights / Wipersro
Car  Renault Clio
Hi,
I recently purchased a Clio 182 FF and I believe my car should have auto lights and wipers?
Is it possible someone has had a normal windscreen fitted and thrown the sensor away and tucked the wire up into the headlining?
I'm asking as I seem to have no intermittent wipe and all the information I've read suggests Clio 182's with Xenons, Climate and Cruise Control should have Auto Wipers and Lights?
Any help will be appreciated :)
Nope there is not light or rain sensor near the rear view mirror.
Am I right in saying it should have if the car has climate, cruise and xenon?
There is a way to turn them on or off. Worth a try to rule out first:
Put the ignition to position 2 and turn your lights on and off quickly twice. Should hear a beep.
OK will that work without the sensor on the window I assume? As the UCH is still programmed to do that?
You'd probably still get the beep but I don't know how it will affect their operation. Might just be constantly on or off I guess.
I think the A/W and auto lights are a great feature
Have you tried flashing when using auto lights or putting fog lights on? The rain sensor isn't sensitive enough, when its raining fine, they dont wipe - its dangerous tbh!
