Coops Mk1
Lots of Scrap...
Mine seem to be not working
I need to get this straight in my head too, if the auto lights are on, the auto wipers are also on and will work when the stalk is set to first click ('intermittent') and look after themselves
if I turn off the auto lights, this turns off the auto wipers and means they work as intermittent on the first click of the stalk and you can use the slider to adjust the pause between wipes?
all correct so far??
mine currently has auto lights on and working fine, but the wipers work on the first click on a set pause intermittent wipe only and the slider adjustments does nothing either? am I to take it this means the sensor is fubar and the car is clever enough to know this and put the wipers on set pause intermittent. but not clever enough to allow me to have the slider adjustment function with the auto light still set to on?
is there a nack to fitting the sensor to the windscreen too, does it need to be pressed right up against the glass?
sorry for the ramble, just pouring my thoughts out as they come
cheers
Ben
cheers
Ben
