B&M Quickshifts - Worth It?
  Suzuki SV1000S
May get one of these for the valver - Are they worth it?
If anyone has a 2nd hand one to sell me that would be nice too.
Ali
  V6, Trackhawk, GTS
I'm getting one in the near future if there's sum interest in this we should try and organise a group buy...
£165 is the cheapest i've found jus now.
  Suzuki SV1000S
Well they look good I suppose - But they must make the change quicker even just from being shorter I guess!
  MKIII 138
i know ive mentioned it before but there is also one for the 172/182 specially designed by BBPT
prolly better looking at the specs than the B&M one
  20VT Clio & 9-5 HOT
just less travel between gears! seem a lot closer!
5th and reverse just feel tricky to get into!
Ali
  V6, Trackhawk, GTS
emm....I tired Rick_172's and his was perfect in all grs...172 tho...mayb a difference there like. It's alot heavier. nice like
  5, 19, Integrale, Cupra R
The vid on BB's site makes the 172 one seem like a very bad idea, he seems to have trouble getting gears and it looks notchy
  20VT Clio & 9-5 HOT
i find changin down to 3rd a bit weird!
have to push it slightly to the left or it takes 2 pushes to get in!
fine once ur used to it tho!!
looks good too hehe
  20VT Clio & 9-5 HOT
u can have a go with mine if i ever meet you lol
you enjoying the 16v mate...? is it stripped yet?
_Tom
I dont find gear changes to bad in mine as standard realy so think i'll leave mine..
Craig when i finaly get to the pod i'll test yours for you! ;)
  Suzuki SV1000S
Well I still haven't actually got it yet lol! It is being MOT'd on Monday so should have it next week - Wheels are still sitting in my room teasing me!!
I don't liek it it does speed the change up but you cannot rush the box anyway as its not exactly amazing.
  20VT Clio & 9-5 HOT
george! i managed to get hold of probably the last set of them wheels in the end! took some serious effort tho!!!
lawrence
  is non-existent
i havent tried driving a car with a quickshft but ive tried it stationery and it does feel very notchy, it feels as if your going into the wrong gear, but it did feel more surefooted though, i can see what your saying about the vid but i think they did it after fitting so it would feel alien to someone not used to it,
anyway im intersted if there is a group buy going
id be interested in a group buy if someone sorts one out. they are pretty good, dont make a massive improvement just reduces the time it takes to change gear thats all.
  Suzuki SV1000S
Think we need to see if any off the companys offer a discount for them to cliosport meebers first, how about demon tweeks?
Ali
  V6, Trackhawk, GTS
MSW are the cheapest at 165 notes and said they'd be prepared to do a discount...
  williamsclio.co.uk/forum
ive recently tested the B&M shifter and the new MB Engineering shifter from BB tunning at williamsclio's trackday at Donnington.
The report isnt fully written up yet, but i'll give u some inside info -
The B&M will need a mod to the reverse lock collar so it will go into reverse gear propally. 2.0mm of aluminium is to be removed ! 5th gear was very funny to get in (appartly something will need to be adjusted at the linkage) like you had to rotate the shifter to the left when inserting. The B&M has plastic parts which WILL wear.
And the B&M sits far to low down and unless you have bucket seats - the feeling of sitting on a high chair is werid in a sporty hot hatch.
The MB Engineering one fits with no mods and is a better height (still not as high as a standard shifter) and produces the same short throw pattern. No plastic parts to wear and a nicer shaped knob....so gets my thumbs up.
Keep checking for my test feature guys - I'll keep you updated.
  MKIII 138
thanks for that m8, is the MB engineering the same one that BBPT sell ?
BenR said:
reverse and 5th become super vauge and you have to stretch to the lever....hate them.
yup, utter pants, i've tried them several times and never liked or been able to get used to them. to get the thing into 5th it was a case of rotating the lever round to the right as well and it popped out of 5th quite often, but also felt vague as hell. the height is wrong as stated and they wear your synchros (sp?) quicker... could explain why certain people that use them go through 2 or 3 gear boxes a year... in all, utter shite, you'd be better burning your money, at least that way it's then spent and it wont damage your already frail as f**k chocolate Renault box.
total pants.
They dont help you shift faster at all and the box's dont like to be rushed anyway.
Plus its now winter, and they are freezing.
surely you dont need a shortshifter to chagne gear as quickly as the box will allow? If you change gear and the box is still at too high revs for the speed in that gear, it just gonna drop the revs anyway. £165 on a shoirt gear stick, or practicing decent gear changes.... I no what i did, and i dont have a short gear stick
Ali
  V6, Trackhawk, GTS
It needs something the 172 throw is massive and very clumsy...i neva had a problem getting ricks into 5th
