Bad misfiring an hesitates when warm
  Clio 16v
I was happy with just unplugging the map sensor an having a higher idle than normal but it was only a quick fix, now after looking harder an changing loads of parts an nothing would get rid of the bags of misfiring when I flatted the throttle, until I disconnected the lambda sensors an it would run perfectly, no hesitation.
My problem is that Ihave already changed that sensor to a NTK sensor I bought from my local factors £76 .
I took it out an changed it back to my old sensor an i ran a little better, but still hesitates.
I did clean the sensor first, now it's still running rough but I don't get a fault code.
  Clio 16v
Il admit Ihave n't been taught how to read much less understand it.
But the reading went from 600-0 on mere tick over
Never a constant like from the rear sensor 450.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
That's correct then, the U/S sensor should switch from rich to lean where the D/S should remain stable. And the MAP value?
  Clio 16v
I don't recall off hand. I will let you no tomorrow.
So if you had a fault an only unplugging the lambda sensors made the car right what else could that suggest?
