as some of you will know and have felti have been having some problems with the car (aka willis) (aka meganesport 225 HPRSV) of late. There is a violent vibration coming from the front end under acceleration between 40 - 70 mph, it shakes the whole car but not the stearing wheel or gear stick and obv something is wrong!
i have had this checked by my local garage and had a look in the net to see if someone had had any similar problems. The garage said that link bar and a cracked top engine stabalizer was at fault so i had these replaced tho these parts were damaged it still hasnt resolved the issue.
there seen to be many sources of "wobble" drive shaft, wishbones, C.V joint and have read about a coil.
has anyone had any similar issues or can shed any light on my problem?
cheers.
cheers.
