banging mongoose exhaust!!!
C
Cupster
Just wondering if anyone has experienced any probs with the mongoose cat back twin 3.5" system for the 172.
First weird thing is that the backbox has to hangers but my clio only has one rubber!!!!
Second is the banging of the system on the rear torsion beam.I have 60mm rear springs which I think is causing me the big headaches trying to fit the exhaust because of the gap between the rear beam and underneath of the car for some bizarre reason Mongoose decided to put a join right there !?!?!?!? Strange, anyway I was really wondering if im alone here or anyone else has anything like this I know there are peeps on here with very low clios and others with similar exhausts.
I have taken the car back to the peple who fitted it twice now and had a look underneath and there is hardly any space at all. I have had a second rubber support made up for the other hanger and had that adjusted to bring the system higher (bring closer to the bumper)but still persists.
Any help or suggestions would be appreciated to get round this.
Tom
  i3
sounds like the rubber has collapsed.
you need to sort out the mount use the search for exhaust mount or sommat
Ali
  V6, Trackhawk, GTS
As above ^^^ The rubber Do das on mine collapsed last week...5min job to get it fixed. Even the Kwik Fit monkeys could manage it.
C
Cupster
I will check that out if the bloody rain stops and see if that has happened, cheers
