Batch to copy then sort csv file
  E39 530i
evening guys, need some help. I'm trying to write a batch file which will copy a .csv file but also sort the contents of it. Any ideas, or help please.
  E39 530i
windows 7, it's just going to be basic text. Two columns, first column with a number, and the second column with a name.
Single line in PowerShell - I am assuming its in a subfolder of C:\ called MyData and you want to sort on Name column
PS C:\MyData> $mycsv = Import-Csv .\Source.csv | Sort-Object -Property Name -Descending | Export-Csv NameSorted.csv -NoTypeInformation
The | are pipes.
  E39 530i
Cheers Spoonie. When i run the ps script it creates the secondary file but the file is all alien text. any ideas....
Not sure, could be encoding. You can split the command up:
PS C:\MyData> $mycsv | Sort-Object -Property Name -Descending
Does that print out to the screen as expected?
  E39 530i
Nop, my fault. Got it producing the file but its not sorting it correct. Below is a simple of the original and the output file it produces
Number Name
21 John
43 Mark
2 Ed
1 Ellen
100 Steven
89 Michael
Number Name
89 Michael
43 Mark
21 John
2 Ed
10 Steven
1 Ellen
What am i doing wrong
What's the output from the following:
PS C:\MyData> $mycsv | Get-Member
EDIT: Its these you want to check:
Code:
PS C:\> $mycsv | Get-Member
TypeName: System.Management.Automation.PSCustomObject
Name MemberType Definition
Equals Method bool Equals(System.Object obj)
GetHashCode Method int GetHashCode()
GetType Method type GetType()
ToString Method string ToString()
[B]Name NoteProperty System.String Name=John
Number NoteProperty System.String Number=21[/B]
That is the property it will try and sort on, not sure why yours isn't sorting. Mine:
Code:
PS C:\> $mycsv | Sort-Object -Property Name -Descending
Number Name
100 Steven
89 Michael
43 Mark
21 John
1 Ellen
2 Ed
