Battery replacement for key
Anyone know how to replace the battery in the renault key fobs (03 cup)
Sorry to be apain and yes I did do a search:oops:
  RB 182
My mates has got the same problem for his Y Reg Clio, hes had the case off before just didnt do it on purpose (i.e. he dropped it). It has work away on the bit that helps you open it so its a nightmare.
Done it:D
Take ring off key
Hold metal part of key by hand holding it so you are looking down at the button part
Place thumb over the top half of key and slide backwards et voila
Battery had just come out on mine so no need to buy a new one!!
  Mk2 Ph1, 1.6 16v Clio
what about the 00 keys? mine is a vreg 1.6 16v and i cant get the keys open for love or money! using the techinque you say above doesnt work. In fact theres a slide indicator and it points opposite way to what you are saying on here on my keys.
One of them has failed already and the other battery may go at at any time so i need to get in it desperately!
DAz sounds like the smae key as mine has the directional arrow, just needs a bit of welly try putting thumb behind it or if not get a flat blade screw dricer and lever the f**ker offf!
  2.0 175dci rs meggy
best way is to get the key with the arrow side face up and put a flat screwdriver in where the key ring goes and lever in the direction of the arrow!!
james
rte bath
  RB 182
Quote: Originally posted by brazo on 15 August 2004
Quote: Originally posted by benclelland on 15 August 2004
I did think about the screwdriver, ill try that one i think.
Watch yer fingers in case it slips though
If its that dangerous i think ill get my mate to do it;)
