Quick Question? When a wheel bearing is on it way out, do you always get play in the wheel. The reason I ask, I'm getting a nasty grinding noise coming from the passage side of the car, and I'm not sure if it's the driveshaft or bearing.
Well I jacked the car up yesterday to check for any play in the wheel which is a sure sign of a dying bearing, and to my surprise there is none, so i'm thinking it's a driveshaft problem.
@TheEvilGiraffe
I fail regularly. Unfortunately. Only today, for example, I was out foraging for berries, got distracted by a butterfly and then slept for 4 hours. End result, no berries.
I can categorically confirm I am not in the OPs hub assembly making grinding noises.
Lol. I thought about you when I saw this thread title too,
But then, tbf, I spend most of my day thinking about you.
DAm, i know this is a long shot, but has anyone got anything to say with the problem.
