adamhodg said:owners manual wats that?
MikeDX said:Its the annoying book that gets in the way when you try and put stuff in the glove box
blink172 said:The doors autolock as you pull away at the start of your journey, and only unlock once you open the door from the inside or throw your car upside down in a ditch.
Bet you didnt know how to set the alarm with the windows open either.
KingTrophy said:A?????? My mates clio used to lock when he pulled off but
mine doesn't, how do you set it?
pbirkett said:My anti-hijack thing doesnt work. Neither does the lock button on the dash. The dealer told me it will never work either due to the way the alarm is wired in.
Not sure why really, but i've had this looked at three times and they said the same each and every time.
blink172 said:Bet you didnt know how to set the alarm with the windows open either.
Nebdingo said:Nope.... do tell!!
MikeDX said:Press the lock button twice?
mij29 said:thanks, i didn't know that. Is that the same for 172?
robbievox said:hmm not sure one the locking with windows as the standard clio key fob (not new keyless entry ones) only locks/arms the doors/immobiliser. My 172 was a motorsport import and had no alarm so I had an extra one fitted (toad sigma 32) which uses the same key fob. I helped the chap fit it and the way it (and other 'bolt on' alarms - same as standard renault uk ones ) and other alarms which do not have an additional arm for works is by tapping into the cars lock, unlock central locking wires for a +ve signal or pulse. The internal central locking switch is also used so not to let a would be thief break in and use the cars standard central locking to disable the alarm.
It seems that possible they have completely removed the internal central locking switch on pbirkett's car to make life easier = pikey way of doing it, either that or they made a hash of it.
For this reason I am not aware / nor think it is available for a normal clio with standard fob to have a dual function to allow arming alarm (which is not standrard @ factory) with windows open (and if a 2nd mode was allowed i think total closure would be much more usefull - think ne1 197 and meggy have along with 1 button up/down on all leccy windows)
edit - am happy to be proved otherwise tho as a 2nd function would be uefull
mij29 said:Going have to go and try it to make sure!!!
blink172 said:Make sure it beeps 4 times to confirm its worked.
pmsl ur kidding?jonesyx said:didnt some people not even realise they had a cd changer untill someone mentioned it on here?
