beeping
  turbo 182
once the car has been started up and moved then turned off or then driven for any duration of time, when i go to lock it, it beeps twice. dosent always do it if i then unlock it then open and shut door and lock again it dosent make the beeping sound? any ideas anyone? cheers
Im sure its todo with the alarm I belive if you turn the engine off then turn the keys back to full position then back out and lock it.
It beeps to tell you its turned the ultrasonic sensors off.
Had this a couple of times so I spent a while searching for an answer .
Ok cheers mate will give it a try next time I'm in the car
