Quote: Originally posted by DirtyDiesel on 23 March 2004
no, inject the fuel through the existing injectors. You can increase both the fuel rail pressure and injection duration using remaps/chipping .
Arr right soory though you didnt know what you were talking about your right you could do this and wire it to a tunning box which switches on only with the NOS its an idea some VAG tunners use for demo cars.
Youll need some one of mapping and big injectors to do this (100dci should be the biggest and easiest) and pump (again the 100 should be good). Turbos good for 1.4bar so with injecotors and remap alone your talking about 150hp. But thats about the absolute limit for the 100 injectors you could have them remade but 150hp is enough maybe the limit for other bits of the engine even.
With NOS well the potential is massive you could be talking about 600hp but the pistons would last 1/100 of a second.
Anyway modifiying the injection period is risky pushing it to far will lead to problem pre injection leads to excess pressure in the piston and to early combustion. Late injection leads to smoke ie melted turbo is pushed to far and excess heatt to the valves.
