Best seatframes for buckets?
  172/1.2/E30
OMP subframes fit fine if you keep the inner spacer things and remove the outers. Subframes offer a nice low position when buckets are installed with sidemounts and without runners.
  Cup In bits
OMP base frames and OMP steel low version side mounts are the lowest I have seen seats mounted without any fabrication. The seat base can sit as low as 20mm above standard seat rails with this setup, it would be solid mounted and you might have to drill a few holes in side mount to get best position but no big problem. Low is better IMO, depending on your size but it gives a better feeling and keeps COG low.
  172/1.2/E30
You can get tilting subframes from Wiechers in Germany afaik. With the OMP subframes you can install sliders only.
