I have just fitted an Alpine amp and sub in the car and i am abit confused at what the ideal low pass crossover setting on the amp should be set to. The amp is an mrv-1005 and the head unit is an dva-9861r i .
Also the amp has a parametric eq switch on it where you can adjust other bits and bobs, should this be used or not, any info on the switches and other settings would be great.
thanks in advance
thanks in advance
