Depends what you want from them really. If you want the easiest solution it would probably be Pioneer, they do a set which is a direct swap for the Renault Clio standard ones, which includes replacing the dash tweeters and door speakers.
No its easy.
You can do it without taking the dash of, if your careful. But sometimes they don't quite line up correctly with the little grills on the dash.
The plastic grills on the dash twist and then lift out. Even if you just have a look to see what they look like,
But taking the dash off is just as easy - look at Fubar's guide in the guides section.
