Will you explain this further please
Back pressure means the manifold pressure in the exhaust manifold essentially (well its the exhaust ports that really matter but same thing effectively)
I did explain it a bit further up.
Back pressure is always bad for all 4 stroke engines but on a turbo you have no choice but to have some as the turbo relies on a pressure differential before and after it.
Gas speed increase from a smaller exhaust pipe is good for low down torque on an n/a engine. But that's about generating negative back pressure at the end of the exhaust stroke. It's not about having positive back pressure. That's always a bad thing.
But to go into a little more detail "back pressure" as a good thing at certain points of the cycle on 2 stroke engines for efficiency as there is a point where both inlet and outlet are open at once for quite a while and it can result in the gasses going straight through otherwise, as a result its got into the phrases that people bandy about as if its relevant on all engines, and it just isnt.
On a N/A 4 stroke engine, there is no point in the cycle that it is ever beneficial to have back pressure.
(slight exception would be if you ever tried to tune the exhaust of an engine on massively overlapped cams to be best at low rpm but thats just not something anyone would ever do as you wouldnt use those cams if low rpm was the issue)
