biiig problem...
Car  Black Dynamique
HELP please!!!
went to go out tonight to find that my lights behind my speedo werent working.
got out and checked all my lights and the back passenger light was out, but the brake light works.
tried a new bulb etc and same problem...
any suggestions?
thanks!!
Fuse maybe? The lights behind the speedo are smd's and iirc dont fail too often. Problem is probably elseware.
thing is, i think my fuses are all in wrong places etc... i've been told it's quite likely something to do with my new head unit..
Yeah new headunit + trapped illumination feed = loss of sidelights. Been there done that.
You will need to check your fuses mate.
i had this and got told it was my headunit! i checked all the fuses and took out the headunit and still nothing. up behind the glove box are some relays make sure they are all pushed up and that they are not loose. i did this and its been fine since
all sorted..
turns out when someone hit me last week it crushed the cable for me rear reg plate light and it eventually shorted out.
fixed now :)
