bilstein b8
theres nothing for the RS models other than the B14 coilover kit. The B8's are for the smaller engined models.
I'll check the part numbers on the B14 kit when they arrive next week to see if they are the same :D
Any reason why you would only change the rears? Mixing and matching with suspension doesn't sound great tbh.
Ah fair point. Just wouldn't want to upset the balance on the rear of the car to the front.
I'd uprate the rears without doing the fronts as standard the car has a little understeer characteristic. This would dial in a bit more nervous handling which I like but to work properly needs to be combined with stiffer springs. :D Effectively this is what the whiteline kit similarly does with the stiffer ARB anyway..
