Bleeding 4 pots...
M
mini-valver
Gonna do mine in a sec, they have 2 bleed nipples per caliper, do I open them both at the same time or do each seperately??
Ta.
M
mini-valver
Cheers fella. Obviously do the rear half where the line comes into first.......?
  Better than yours. C*nt.
Doesn't make any odds, just one you'll have to bleed for hours if you're doing a flush, the other will only need a bit of bleeding as the fresh fluid will already be in the line to the caliper.
  TT 225
the one furthest away so that would be:
  1. back right
  2. back left
  3. front left I THINK
  4. front right
couldnt say for sure though lol
M
mini-valver
Im going to gravity bleed them anyway while im doing otherstuff so not hugely fussed how long it'll take, just leave the MC full and keep an eye on the fluid dripping, lol.
Cheers Mike, will do the closest to the line first then as the other side is fed from that side anyway so should partially fill the caliper.
