Block/filler primer?? Professional opinion!
  Astra van,Mk1 nova
Im looking for a professional opinion on block/filler primer. How well does it work? Im guessing it has to be flattened after its been spayed on the car? Why do bodyshop use this filling primer?
  Clio 172 RS2
Not OneHundred percent Pro.
Done the odd car, car parts and mainly doing helmets and bicycleframes.
Flattened as in sanding down yes... depending on how smooth the primer was applied and if there are any irregularities in it. (cut it down with Grit400 sanding paper or a 3M Scotchpad)
Filler Primer is for a better adhesion of the basecoat, something to grab on.
To smooth things out (quick filling), like when there's no reason for a thick filler putty over a repair area. To seal things off, like putty sucks in more paint then a sanded-over O.E.M. paint area. It evens things out.
On a final note, give it some quality time when prepping!
Proper prepping always shows through in a paintjob. Might be hard graft or it appears like going nowhere but do it!
Gally
Lol filler primer is a bit old school mate, you should be looking at getting the repair right first then use "heavy build primer"
  Astra van,Mk1 nova
Im no painter mate, think the correct term im looking for is high build primer. The paintwork on the nova is very very bad so its not just a case of rubbing it down smooth, if i wanted it very smooth it would have to come back to the metal its that bad, hence the reason for high build primer. I spoke to the painter today and he said that he's more than happy to high build it then flatten it before painting.
At the end of the day its a 23 year old nova track day weapon so a concours finish is not very high on the list of priorities:cool:
Gally
Lols. The bodyshop sounds ideal.
High build primer then flatten, job done!
  Clio 172 RS2
A Track Day Weapon? -Ka-POW-
After those bucketloads of high-build filler... it will gain some weight!
Render it a thick very unfit Nova!
