Blue Brake Discs....!
  Clio 197
Knakkered?
(I just wanted a second opinion before I click "order" on demon tweeks).
Freds already told me the bad news.
  500bhp Scoob
id say so...
sounds like youve cooked em nicely lol
[Edited by Mole on 7/25/2005 11:05:19 PM]
Not that ive ever seen blue brake discs, but ive seen metal thats been heated up too much which has turned a blue colour
  Clio 197
Smoke was coming off-em @ brands and the ring...
The heat coming out of them was rediculous...!
I dont know whether to have them skimmed, or just order a new pair of the feckers...
If I do, Ill get the brembo as recommended by Fred.
EVOgone
  Pink Cup Racer
Agree with the brembos - £60 from GSF, mine came yesterday. Might look to see if i can get some ducting from the front to the disc hubs, it cured my brake problems when i had the EVO.
dk
  911 GTS Cab
why do disks go blue then, my one disc was blue after it was put on Fred, now I have lots of squeaking and a loud noise sometimes at 80 on the motorway?
  Lionel Richie
which one dave?? theyll go slightly blue during bedding in especially when running those pads
enthusiatic braking will sort it (dont go crazy though!!!)
you have to get the pads/discs through the intial heat process so all the resins + dirt etc are bedded in/burnt off
how does it brake???
  Clio 197
Discolouration due to excessive hot/cold/hot/cold/hot/cold...
AFAIK...
Either that, or someones put them in a dishwasher!
EVOgone
  Pink Cup Racer
So a new set of discs.... or not?
:confused:
Dont want to waste hundreds of pounds.
Brembo discs are only 60quid. Get them swapped.
  Clio 197
Lol.... everyones telling me to ge them swapped...
Do you have a direct link to the item? I dont want to go an order the wrong ones now...!
Mr Yoz can get them for you I believe!
  Lionel Richie
ooh Dave, cant remember if i told you or not, but it might be worth while you getting your brakes bled again
i know its an arse, but i was working in a car park LOL!!!
just the ABS system is a bit of a bugger, worthwhile to get it done anyway
itll be fine etc, but i just like to be sure
  Lionel Richie
yes we have them in stock
EVOgone
  Pink Cup Racer
https://secure.gsfcarparts.com/shop/basket.asp">https://secure.gsfcarparts.com/shop/basket.asp
Ask for Julie when ordering, very helpful 24 hrs delivery
dk
  911 GTS Cab
Quote: Originally posted by Fred2001Dynamic on 25 July 2005
ooh Dave, cant remember if i told you or not, but it might be worth while you getting your brakes bled againi know its an arse, but i was working in a car park LOL!!!just the ABS system is a bit of a bugger, worthwhile to get it done anyway itll be fine etc, but i just like to be sure
yeah, was thinking about it, the brakes are amazing, very very good, not too sharp either, if you brake right it doesnt put you through the windscreen.
As I said, I have a bit of a squeak problem at the mo, even when not braking and driving at up to 40 mph.
Then there is this noise I get on the motorway sometimes like I have flat tyre of something, my only thought was maybe a warped disc?????
Oh and you also forgot to mention the sparks LOL, scared the sh*t out of me the first time i drove it in the dark!!!!!!!
The PF97 pads and Brembo Max discs make a lovely, pretty sparkler effect as they grind against each other under hard braking in the dark LoL
Im sure that Yoz or Lee has a pic they can put up! Looks cool :cool:
Im tempted to swap to those pads simply for that reason alone LOL
dk
  911 GTS Cab
Quote: Originally posted by White16valver on 26 July 2005
The PF97 pads and Brembo Max discs make a lovely, pretty sparkler effect as they grind against each other under hard braking in the dark LoLIm sure that Yoz or Lee has a pic they can put up! Looks cool :cool:Im tempted to swap to those pads simply for that reason alone LOL
LOL, I am yet to do it next to another car to see what they think, but it did scare me the first time.
Cant wait until the night run at the meet in maidenhead tomorrow night
seb
  Clio trophy
changing bits like that whilst the clio is under warranty doesnt effect it does it?
  Clio 197
Its not like their warrantys worth it, Lol!
I paid to get my temperature sensor fixed myself... to avoid taking two days off work to do it under warranty.
Bunch of pikeys!
seb
  Clio trophy
lol^^^^^^^^
you had the oxygen sensor done yet as well then?;)
The PF97 pads and Brembo Max discs - how much and are they noticably different from the standard set up?
  Clio 197
Yoz and Fred are the guys to speak to...
They do a full kit of Discs, Pads and braided hoses.
Lets put it this way: In town - you wont notice the difference...
As soon as you get some heat into them: Theyre stunning.
The pads are essentially sandpaper, and so you can imagine the stopping power.
(this is all AFAIK of course... pm Yoz / Fred).
dk
  911 GTS Cab
omar is right, i thought the 182 setup was good but it is nothing compared to these, and i havent even got them on track yet but they are so powerful the abs is having a job to get the car not to stop on the spot.
