Boot light and rear washer
Coops Mk1
Car  Lots of Scrap...
two niggles on my 2000 x plate 172 phase 1
boot light doesnt come on when you open the boot, but if you open door it does so presuming switch is gone, is this part of the boot lock? can it be earth issue or new latch assembly required?
rear washer doesnt work, when i press the switch it washed the front again, so guessing i need new pump?
any advice much appreciated
cheers
Ben
I've got the same problem with my bootlight Ben. Also 172 2001 phase 1. The bootlight only reacts on the doors. Problem is, it drains my battery as well, that's why I had to disconnect it. Have you already found out what is causing this?
