Bore???
Ok, am I right in thinking I can fit a wheel with a larger bore using sprokets?
If I were to fit a wheels on the front with a smaller et, the tracking will be out can this then be re tracked so it works?
thanks.
yep you can fit ones with a larger bore using spigot rings.
not sure about the second part..but if the offset is smaller you might be able to use adapters.
Cheers.
I would purposely have the offset less on the front wheels so they stick out a bit more to make handling better.
I have Borbet A 7.5" on front and 9" on rear they were fitment for Clios.
you need to think about rubbing issues as lots of peeps have to remove their arch liners because of it.
A little piccy...
