braided fuel hose
Tomo3292
Car  Clio 1.6 K4m
Gents
I am after some advice with regards to braided fuel lines.
I am building a budget rally car, and looking to Install some braided fuel line from the pump to the fuel rail, and a bit unsure of the size and what connectors to purchase.
Any recommendations advice is most welcome
Gents
-6 braided line and get your original fuel pump fitting swaged on. At the fuel rail end you may be as well to swap it out for an aluminium rail and a proper AN fitting.
Been to a few rally's !ate and just seen them run braided line from the fuel pump to the rail.
All seemed to use the standard fuel rail. But then again I think maybe its done on a budget?
I'm in the process of doing this now as moving all the fuel and brake lines to run inside the car. I have done as mark suggested but retained the standard rail
