Brake discs stuck on? Read this
Car  Clio 182
I was having trouble removing stubborn rear discs on my 182, with heat, levers and sledgehammers having no effect. Stumbled across the Draper Hub Puller which bolts onto the disc using wheel nuts and uses a large bolt that is tightened against the spindle to pop the disc off. It took about 1 second to pop the disc off with no effort at all!!
Hope this helps someone in the same situation.
~ Josh
https://www.amazon.co.uk/dp/B01EAKFJWO/?tag=cliospnet01-21
