Mk1 MX-5 (x3), Westy
Hi guys,
Currently messing around with fitting some brake ducts to my 172 Cup. Got arch liners out and carbon canister removed so a bit more space to play with.
My original plan was to run a 2" silicone hose from a custom made inlet where the fog lights were, strapping it to the lower wishbone pointing directly at the rotor. I've got one fitted but there's not a lot of space, had to squish the hose to clear the weights on the inside lip of the wheel!
Since then I've seen a few links where people use ~100mm ducting and a deflector plate instead:
http://www.cliosport.net/forum/show...Featured-***&p=5609297&viewfull=1#post5609297
http://clio-motorsport.blogspot.com/2008/12/brake-cooling-ducts.html
Anyone done 'my' method before with success? I think I might be doing it the hard way, as the deflector plate method looks a LOT easier... However the other brake duct systems I've seen before seem to direct air directly at the rotor?
http://image.musclemustangfastfords...7_steeda_Q335_mustang+brake_cooling_ducts.jpg
http://www.britishracecar.com/JohnMcCue-MG-Midget/JohnMcCue-MG-Midget-DF.jpg
Cheers!
Adam
Cheers!
Adam
