Brake Hubs
  1.4 mk3 Clio
Ok i have disc brakes on the front but i have the hubs on the rear i was wondering if i can put discs on the rear and if so how much?
I have a Mk3 clio.
Da
  Less
I think the easiest option would be to change the rear beam to a Clio that uses rear discs, such as a 197.
I know that's the way to convert the Mk2's, not 100% on the Mk3's though.
  Astra 1.9Cdti SRi
Agree,
But you may still get problems with the ABS system, something about different ring and different sensors not corresponding with each other causing it not to work
Da
  Less
Yeah, as far as I know the rings up front would need changing to match the rears (or vice versa).
Not always as straight forward as it seems.
Well, it can be done on a mk2, I've done it.
So it should be possible on a mk3. Best option would be to have a good look at the drum setup, and then studying a disc setup and seeing whats different. Though logic would be a beam sway would be the most straight forward way of doing it.
