Brake Pedal Switch Wiring
GasManLS7
  Clio 182
I'm looking to wire a brake light switch into my pedal box and currently have this type:
I still have the connector and wiring for the original brake light switch but it has 4 wires:
Does anyone know what each of the 4 wires is? Can I wire my new brake light switch into those?
Brigsy
  T.Turbo
All on visu see attached pdf.
160 is the brake light switch.
1016 is passenger side fuse box.
120 is injection ecu.
172 & 173 are rear lights.
Be easy enough. Id stick it in between pins A1/B1 & A3 to test, prob work ok..pins will be marked on the plug.
  • 0082_A4.pdf
GasManLS7
  Clio 182
Hi mate, would you leave the other wires in the connector and just cut and splice the ones for the switch?
