brake problem
Craig
  4 wheels
Just had the car hooked up to a diagnostic machine because my abs serv light and traction control are on. It's come back that it's both rear speed wheel sensor open curcuit. Is it a easy fix?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Did it just suddenly come on? I'd check the main connection under the car as its rare for them both to just go.
Craig
  4 wheels
They've been on for a while now. I was just waiting for time to get it looked at. Where abouts I'd the main connection mate?. I could check and look
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Under the car on the passenger side.
Just follow the wiring and you'll find it.
Craig
  4 wheels
Had a quick look this afternoon before it pissed down it looks ok. How could I tell if it's fubard?
Craig
  4 wheels
OK mate cheers hopefully if the rain stays away I can have a proper look. How much are new sensors if they are knackered?
  dan's cast offs.
touch over £60 each, unless euro keep getting you the wrong one and it ends up at £25!!
have seen them without the bearing spacer fitted and they've mullered the sensor.
Craig
  4 wheels
OK mate cheers will have a look. Hopefully its the right part to start with
Craig
  4 wheels
@bloke while the car is off the road now. You don't happen to know Wether the code is the same as yours do you?
