Brakes?
  Sunshine Bus ph-quick
I need new brakes. Stopping is becoming an issue. oopsie!
Any recommendations? Don't wanna spend a bomb since its only a 1.4 and I drive nicely so don't need huge anchors..
Debating track time at Trax, so I'd like to be able to stop
Ta
x
  Mr2 Roadster
Any new set of standard brakes from a cheap motor factor will do for you once they are run in.
I run standard pads and discs on my Golf which I rag around for work and they are more than fine.
You may want to get your fluid changed at the same time as thatt will make a suitable differance to a car of any age if it hasn't already been changed.
