Break Hub: Which fit?
brake hub?
front or rear?
Front from a 1.2/1.4/1.6 would fit, as long as the bolt spacing for the shock is the same (could be 52/54/58mm IIRC)....
Rears (drum) are interchangeable, but there are different versions, you would have to make sure the replacement had the same ABS ring (number of teeth)
