buckets and airbag light obv on now
  CLIO PH1 172
put bucket seats in today and now obviously have the common airbag and service light on
can i use the same resistors i used to cut the steering wheel airbag out with in the seats??
  Cooksport Fleet
I have some resistors here mate, you could have had them. You can put resistors in the block connector under the seats.
Maplin Sell them, if you do a search on the forum there is quite a lot of info about where to put the resistors and which ones are needed.
  CLIO PH1 172
yea i got loads of resistors from when i done my steering wheel i was just wondering if i can use the same?? think there 3.9 ohm
Rob
Are you taking all your carpet out Ad? If so I'd love to have a look at your airbag wiring if thats ok? lol! I need to make an alteration to mine, but could do with seeing someone's first, and obviously if you're stripping, it'll be easy to see!
