buckets!!!!
are recliners much heavier than Bucket seats ?
22kg each for the standard airbag seats is quite heavy that means you have saved over 30kgs !! very good.
how much would a recliner weigh as it is simular but has rotary controls on.
you can keep the back seats in with buckets/recliners but how do you correctly link the harness for full safety do you link to points under the rear seats ?
Ross, i quite like yours as it is....propper street sleeper style, luckily i know what work youve had done lol. Looks like a normal 182 at first glance then u spy the brembos ;-) and it gives u a subtle clue...
recliner would be around 12kg each i would guess
the belt from the harness basically bolts to the floor, you can use the same point where the rear seat belt clips are
