Take off the entire dash board hood thing (3 screws along top, one at either end also).. this reveals top of instrument panel. Take out two screws... next remove bottom screws by unscrewing panel below steering column and peering up (with your back bent double) and you should see two more screws. Remove them and the instrument panel comes loose. Remove the wiring leads and the speedometer cable. Instrument panel them pulls out. Bulbs in the rear.
Sounds awkward... is first time... after that its a doddle!
