Business Routers
We currently have a BT Business Router 2700.
As it only has 4 x Ethernet ports, we have 3 machines and network printer using all 4. We then have 3 machines/laptops using wireless.
Can anyone recommend a bigger router to use? With something like 8+ ports?
Is setting up a new router on a business line, the same as at home? Ie just plug and play?
Any advice or the best way to go?
We also use the current router for VOIP x 2 lines.
Easiest solution would be to buy a switch. Basically acts like a splitter for more LAN ports. Plug one port in to a LAN port on the router, then you'll have x amount more ports depending on what size switch you buy.
