Hi,
Just fitted all my sound sytem in my car...
Deh-p9800bt headunit
JBL 1200W sub
JBL 6 channel Amp
JBL 6 x 9
JBL 80w rms 16.5 components and tweeters.
I have everything running off the amp. The pioneer head unit has rear out, front out and sub out so all them go to the amp. Then the speakers and sub off that.
However when no music is on there is a buzzing noise coming from the speakers. Even when the sound is turned down. Only way it goes is unplugging the inputs for the front / rear speakers from the amp or turning the input level down on the amp to 0.
Anyone familiar with what causes this buzzing? I have not got it turned up to a stupid level, and from what i can see there are no shorts in the wires. All the wiring was done by me to a very high level and is all fresh (ie not used original speaker wiring which came with the car)
any help appreciated.
Thanks* edit, also the pitch of the buzzing goes up/down when you jab the accelerator. This makes me suspect its a power issue or the amp faulty?
and for info, i have done as per the best and ran the speakers and inputs down the opposite side of the car to the power and the remote on.
JBL 1200W sub
JBL 6 channel Amp
JBL 6 x 9
