Calliper removal
  mk2 clio campus sport
hey
I need to remove my callipers today. just wondered if anyone on here could giv me a little guide before i get stuck in.
thanks
  Astra 1.9Cdti SRi
removing the top part is easy, only 2x13mm iirc but you will need a spanner tho as it will just turn unless you grab the part were the rubber is.
the bottom part is 2x18mm and is hold on behind the disc, best way to remove it is to turn the steering wheel to full lock,
