Cambelt and possible timing out
Im not expert on cambelts on these but you need 150 Quid's worth of timing tools as its not as simple as sticking a drill bit in the holes like on other types of engine.
If you don't have the tools then consider a specialist as labour will be about as much as the tools required..
Hi , its not a simple task on these F4R engines and if not done correctly using the proper timing tools you can cause engine damage or loose power if not timed up properly
True just trying to save 60 mile trip to diamond motors with not do great belt and i pretty sure timing iffy haha
Walk to the train station and spend the day in Nottingham. Plenty to keep you occupied.
