Camber Bolts & Rear Camber Shims
MarcB
  182 Trophy & 197 F1
Not too sure what these are about so looking for some advise on these.
What is the point of these and what do they do ? Are they also worth getting and if so what difference will i see?
I will be also getting my sachs suspeion refurnbished aswell as fitting AST solid top mounts along with ARM poly bushes so just looking to really upgrade the suspension and get things well set up heance asking about the above products
Keith185
Camber bolts allow camber to be adjusted on the hub/bottom suspension strut.
Camber shims are fitted behind the rear hubs again allowing camber to be set, these come in fixed values depending on requirement. Although whitelines ones are slightly adjustable iirc.
Think the AST top mounts are adjustable to allow for camber setup or castor, so might not need camber bolts.
Basically there all to change the suspension geometry from factory.
