Camber correcting bolts Camber settings
  172
Hello all,
I have a MK1 Clio which is lowered 35mm on the front, 40mm on the rear with spax adjustable absorbers. I have just ordered some camber bolts for the front, will these make much difference? What settings should i use? I have been told to go for 1 degree negative with my tracking slightly like \ / ?
Thanks in advance
Bottom of the wheels should be wider than the top ie looking form the fornt like this
About -1 degree should be fine but with just springs stock usualy ok setup no need to adjust just get the tracking checked.
