Can’t Squirt....
  Clio 197
Ok... this isnt a serious problem, however:
Rear wash/wipe only dribbles. Not squirting.
Any ideas?
Regards,
Oms.
  Clio 197
Pump makes noise... front ones work. I press the button for a while, then five seconds later, fluid dribbles out slowly (hardly cleaning the window!).
  FN2 Type R +MK6 Golf
The washer pump works on a forward/reverse pump action.
When you press the front it spins up one way and spins the other when you go for the reverse.
If you have warranty get it done,otherwise save some pennys
ian
  Clio 197
Thanks guys...
I just thought they were all like that... but it you think it should work properly... Warranty it is then! Suppose, 3 month old car, so it should work really...
Next thing you know, theyll blame it on my ice install (although it isnt fitted yet, but will be by the time it gets to them)...
gnite.:sick:
