CAN ANYONE HELP GIVE ME SOME ADVICE
  renult clio 1.2
can anyone help me ive seen the forum up i just carnt find it. i just recently brought a clio 1.2 16 valuve 03 plate and she seems to run really well most of the time, but the dash board warning light comes on (center one) and it will idle like driving a feekin tactor.is it a senor to do with the throttle vaulve ? and can some one tell me where about its allocated. or advice me on the best course of action cheers guys.
  renult clio 1.2
thanks pal ill try that from what i have read abit of it is something to do with the map senor wires loom or something as its a pre 2004
Sash
  A Yellow One
Idles like a tractor... Sounds like its dropping a cylinder.... Injector? Leads?
  renult clio 1.2
nah man its just checked cannot see the black metal box were is it allocated, and all i can see is them plastic covers holding the wires in place , and thanks sash only happens when the warning light comes on mate then when i switch the ignition off and on its o.k again
  clio expression
Revised sensor it blue, yours is black i guess? Easy to fit and cheap from Renault
  renult clio 1.2
just asked me mate he say has had same prob is the coil pack had the same symptoms as mine
