R3k1355, thanks Pal but I'm sorted now but appreciate it.I have an old unit that came from China with software in a shed somewhere, will see if I can find it.
Might be on a CD tho![]()
Clip interface needs to be plugged into the obd port to power up. No power lead required
You were partially correct mate as usb does do something on the interface from memory, but needs to be in the obd to work fullyI stand corrected![]()
You were partially correct mate as usb does do something on the interface from memory, but needs to be in the obd to work fully![]()
