172.com Car 172 Apr 9, 2008 #2 Are you using sopcast? I don't have a 360 so not entirely sure what's on there, but if it has a video player capable of running from a network stream it should be possible. If you have Sopcast and VLC, you will need to open VLC and choose the stream http://127.0.0.1:8902, and choose to stream that out. Should be available from your 360 then e.g http://your-comp-name-here:1234. You might even be able to get it from http://your-comp-name-here:8902, without using VLC, but I'm not sure.
