Can you buy the rod part of the master cylinder?
Car  Clio DCi 100
After ages of trying to figure of wot could be causing a click noise from my clutch pedal we've finally worked it out. The clutch is hydraulic and in simple terms: at the top of the clutch pedal is a ROD which pushes the master / slave cylinder of the clutch.
The plastic rod on mine tho has got weak and doesn't stay on properly, hence when it comes off it makes a click noise...
So.....
Can i buy a rod and where from? its plastic i do beleive but i don't wanna hav to buy the master cylinder too
Its a dci 100 btw
Can you see the bit your on about in this pic? Is it the rod coming out of the clutch master cylinder (no.1)?
