Hello all,
History:
The car is a Clio 182. It is standard apart from lowering springs and a K Tec cat back exhaust. When I brought the car 6 months ago it ran fine but always felt a little lumpy.
One month ago the car had a full service including plugs and had the K Tec fitted, after this the car felt a bit lumpy on idle but was so much smoother when accelerating.
Issue:
On Friday I drove to work, the car felt fine and had been run for about 10 minutes so was up to temperature. I stopped at a set of lights and the engine cut out. I turned the key, all lights lit up and the engine turned over but would not fire at all.
I was towed home by the RAC, there are no warning lights on the dash so he stuck the code reader on and got the following:
DF004 – Sensor coolant temperature – Intermittent
Does this mean that there is a sensor somewhere that I should change?
DF308 – Changeover valve for induction damper – PRESENT
Even the RAC guy was not sure what this was, he called the call centre and was told it relates to a particle filter, as the air filter was changed at service do you think this could be the fuel filter? Is the fuel filter in the tank?
DF110 – Misfire causing catalyst damage – Intermittent
I guess that this is a result of the above two issues?
Sorry for the long post and thank you for reading, any help much appreciated as I am a bit stuck at the moment!
History:
Issue:
