Car steers slightly left under acceleration, advice please
Hi all and thanks in advance for any advice/help on this topic
went to get my tracking done and as i suspected it was slightly out. Had it done on a laser 4 wheel tracking machine.
They reset the tracking and checked all setting and said i was good to go. The car veered slightly left when i accelerated so i returned the car they altered some setting again and still the same problem.
They had the settings listed so i dont know if their settings are incorrect.
The car drives quite straight when coasting but under load suffers from this problem.
I had exactly the same problem many years ago on both my clio williams and never got to the bottom of it, but would like to this time as i intend to do a few track days.
Any one else suffered with a similar problem and can any one post the settings they use, the car has 4 brand new tyres, the pressures are correct. It has standard suspension etc.
Am i also correct in thinking the rear cannot be adjusted
Once again thanks for any help, I am based in bucks and recommendations on who can set the car up?.
  172
Ive seen this before ( not on a clio ) and it was the bottom arm bushes worn, The car pulled one way when accelerating and the other way under braking.
Something to check.
