central locking/ immobilizer problem
  renault clio 1.2 8v
Hi, just changed head gasket and timing belt on my clio 1.2 8V 00reg, took battery of whilst i was doing this as it needed a good charge, put everything back together including new coil pack. when i turned the car over it would not start, i rechecked timing,took cam sensor off and cleaned it check everything else but still no luck! I then noticed the electric windows did not work. I also realised the immobiliser light does not come on at all also that the central locking did not work on the key or button in the car, i have checked all fuses and all seem ok, i have been reading thro the old feeds and found similer problem and they all seem to point to the UCH, does anybody have any ideas?? I need help PLEASE
