Central locking stopped working
  clio sport 172
I went to unlock my Clio 172 last night by the key fob and nothing happened. I presumed the battery had gone so I changed it and still nothing. Any ideas? Thanks
  CursedTitanium 182FF
Try re-syncing your key.
RENAULT
CLIO II, KANGOO & MASTER INFRA RED RESYNCHRONISING
1. Turn Ignition OFF.
2. Press the central door locking button for more than 5 seconds. Note :
the door should lock then unlock.
3. When this happens, 10 seconds is allowed and the immobiliser warning
light illuminates.
4. Point the 1st key at the receiver and press the button twice, the doors
should lock and unlock. Repeat for other remotes as required.
5. Check the remote control unlocks and locks the doors.
CLIO II, KANGOO & MASTER RF RESYNCHRONISING
light illuminates.
4. Press the remote control once, the doors should lock and unlock.
5. Repeat for second remote if required.
6. Check the remote control unlocks and locks the doors.
  Mk2 Ph2 1.2
Or the switch has fooked, I fix them all the time at work. Mine done the same thing. Renault dont put enough solder on the microswitch legs so they come off. Solder them back on if you can. If not send it to someone who can... *cough* :p
