changing xenon bulbs
Craig
Car  4 wheels
How easy is it to change the bulbs without removing the bumper
Im sure there was a guide in hear.
The best advice I can give you is take the bumper off. It takes about 20 mins first time you do it and you'll realise why once you've got it off, that doing it that way is so much easier than trying to squeeze expensive and fragile bulbs through a very small gap with hardly any manuverability.
Gives you a chance to clean up the bumper and headlights aswell
I removed my xenon headlamps completely when i changed my bulbs, considering how fragile the internals of the headlamp & the bulbs are, an extra 20 minutes seems reasonable to make sure everything is fitted carefully.
if not taking bumper off mind and pull fuses for xenons and leave to discharge before changing, likewise allow to discharge if removing headlight.
Ok i think i will take the bumper off then. I fancy 6k bulbs instead
